Discuss BAFFLING smoke alarm problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
That's the standard pendant light, Swithed live, N, and loop,
I've jumped off the loop, N and earth
If the 'standard pendant' has been connected & wired by someone else, are you sure that has been correctly wired up? If not, and the sw L, lives, and neutrals have been mixed up, adding the loads (smokes), could present voltage at the neutral of the light when its switched on.
Edit; previously incorrectly wired/connected pendant, would still illuminate when switched on, even though incorrectly connected.
If the only thing that has changed is the addition of the smoke alarms then the only way I can see that they would cause this operation is if they are connected in parallel with the switch, and therefore in series with the light.
When the switch is closed the smoke alarms will be shorted out and when the switch is open they will be in series with the light.
I've checked it, everything is correct
But the same would happen with only 1 detector connected, but it only happens when both are connected
Reply to BAFFLING smoke alarm problem in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi Folks.....I'm replacing hard wired interlinked smoke alarms with new battery interlinked ones. I disconnected old alarms and left the wires...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
