Discuss bench mounted pillar drill running at a reduced speed even when its not under load in the UK Electrical Forum area at ElectriciansForums.net
Re: bench mounted pillar drill running at a reduced speed even when its not under loa
Seized bearings, incorrect voltage, worn brushes, damaged windings, incorrect gear selection, worn drive belt......
i was thinking its going to be more on the lines of the reduced voltage causing it.
if it was three phase id say maybe a phase is down.
what could it be on single phase to reduce the voltage
would it even start??
Voltage drop .... how long & what Cross Sectional Area is the cable feeding the workshop / drilling machine?
Just a couple of suggestions of the top of me heid bonny lad. :)
(could be complete bow locks of course)
Is this a real or hypothetical drill?
If it's real;
Reduced voltage is the most Unlikely cause.
Mechanical faults would be the most likely.
Is it making any noises?
Does the chuck shaft spin freely with the belt off?
Does the motor speed vary by much with the drive belt on and off?
Is the belt loose?
Is the belt tight?
Does the motor have built in brake?
Then move on to electrical faults.
If it's 3 phase it will start on 2, the motor has no load on it.
What's the incoming voltage/s at the switch?
Same again at the contactor if fitted.
And more..
I'm guessing that it's a question for one of your papers?[/QUOTe
If it is the answer will be in the material that you have already covered , they will not expect you to know that which you have not been taught; unless you have been given an assignment that you have not done lol.
As you are the person starting the thread surely you know if it is single or three phase drill?
As geordie spark said it would not start if it was a phase down
If it's real;
Is the belt loose?
Is the belt tight?
And more..
Aye, but the motor does have a load on it. It will have the load of the drill spindle & the drive - belt or gearbox - connecting the motor shaft to the drill spindle.
Reply to bench mounted pillar drill running at a reduced speed even when its not under load in the UK Electrical Forum area at ElectriciansForums.net
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
An odd question granted but bear with me. I've got to extend a radial circuit in a community centre to fit a new hand dryer in the toilets, but I...
Hi, First of all I must explain why my posting came to be on this site, I was looking on the internet for a forum that could help with a project...
Hi there, Just a quick question. Does a main protective bonding conductor require UV protection when run outside? I am under the impression that...
