Discuss Burying fiber in flexible conduit from house to garage in the DIY Electrical Advice area at ElectriciansForums.net
envy2578
Hello, I am burying a fiber optic cable so I have internet in my garage. I have purchased the following flexible conduit to run the fiber optic cable inside:
Diameter of the Kabuflex 40 mm.
*Inner diameter: 32 mm.
I have dug a 20m trench 60cm deep. What I need advice on is the transition from inside to outside. I don't want to drill a hole in the external wall large enough to feed to conduit through. I assume I need a junction box and adapter on the outside of the wall that the conduit connects with?
Fibre optic is specialist cable needing expensive tools to terminate properly.... would CAT6 data cable not work?
The cable is already terminated. Just needs care when pulling through conduit.
Buried Ethernet can cause equipment failure when there is a lightning strike.
Reply to Burying fiber in flexible conduit from house to garage in the DIY Electrical Advice area at ElectriciansForums.net
Hi, I'm a DIY'er looking to build a 6x8 shed in my backyard in Colorado. I'm installing a gravel pad first, with 4 concrete Sonotube...
Hi All, Newbie to the forum. I am planning to add solar power to my house and would like some advice regarding options with adding and inverter...
I've been called in to complete a job started by someone else and I just wanted to ask the following: Basically it's to provide power to a garage...
I have an electrician installing new circuit from my existing panel to a new subpanel in my detached garage. The subpanel is in the inside wall of...
Short Version Is it permissible to have 2 feeds to 2 separate consumer units in a detached garage? Is it permissible to run SWA underground...
