Discuss Can you help me identify this cable connection? in the DIY Electrical Advice area at ElectriciansForums.net
Amit noti
Hello guys i wanted to see if anyone knows what is the connection in the picture attached
Reply to Can you help me identify this cable connection? in the DIY Electrical Advice area at ElectriciansForums.net
Can anyone help me identify which wires should go where on the little brown sliding switch?
Replacing a light fixture in an older home. The ceiling box has two cables, each with a hot and a neutral (photo attached). The old fixture had...
Hi all, I am about to fit a light fitting and wanted some advice whether I should just connect the light cables into the correct terminal blocks...
Hello. I have an optima xm6 alarm system. I am trying to identify the two 1.6A fuses on the right hand side of the board and what they cover...
Hello - I'm looking to help determine how many connections are allowed on my AC disconnect terminal lugs - Eaton DPU22R. I'm not seeing anything...
