Discuss Cheap Aico Smoke alarm alternative in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
S
saabuldin
Hi guys hope any of you can help me here.
Im gona fit 30 smoke and heat alarms in a block of flats. I normally use aico as they are very good and easy to fit. But because theres so many i need im looking for a decent cheaper alternative.
Is there any other good makes but cheaper then aico.
Best price I got for aico is £10.95 each for smoke alarm and £24.90 each for heat alarm. + VAT
Thanks in advance
Aico is one of the few pieces of equipment that I have never had any complaints about. I would be very reluctant to change to another brand to save a few quid. Give your wholesaler a hard time for the quantity, although £10.95 inc is'nt bad.
For what you might save on units you may pay for in call backs.
Yeah i think your right. the job is quite far away and i cant seem to find any other good brand like aico so ill stick with them. Just gona try and find cheaper heat detectors now.
I wouldn't replace Aico with a cheap unknown!
Why don't you call 2 or 3 local stockists and see what sort of deal they will do. I've got a very flexible local independent dealer, who at times, is very, very competitive!
I fitted a heat detector today supplied by the customer and it was just as good as aico to fit and in some ways better. I looked it up and its a bit more dear then aico so im sticking with aico.
The one I fitted is "2nd generation Kidde fyrnetics slick range with rechargeble battery built in". anyone used this one. I like the connections on it which is easier to install then aico. It also has a hinge so the slide on detector is always there with you and can be easily removed if needed. Quite slick definatly.
Reply to Cheap Aico Smoke alarm alternative in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
We have a domestic fire alarm system in some leasehold properties. The existing BRK alarms are no longer available in the UK. These alarms/system...
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
Been covered before, but wondering if any amendments recently. I’ve been asked to fit detectors in a bungalow holiday cottage. Just over the...
Not come across this before, so would like some help, please. I went to install smokes and heat alarm (to new Scottish regs) in a fairly modern...
