- Apr 14, 2020
- 101
- 34
- 103
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- All Other Countries (This Is English Speaking Website Only - WE don't mind Google Translate Users :)
- What type of forum member are you?
- DIY or Homeowner (Perhaps seeking pro advice, or an electrician)
Hi guys.
Moved in to a new house last year. We have underfloor heating in all of the rooms. 10 zones.
I see they have chinese copies of Honeywell t6360c thermostats. 10 years old.
First test I noticed the thermostats turn off after about 5-10 minutes.
The thermostat housing where the side switch is located warms up and of course heats up the coil giving a false temperature switching it off.
The wires on this switch inside seems to be of a thin gauge!!(much thinner than the load) Chinese copies I'm not surprised. The load travels through this switch.
So I bypassed the switch with a thick wire across the appropriate terminals.
This prevented most of the warming of the thermostat casing.
But still the coil seems to absorb some heat from the main 16amp connections giving false readings.
I would say the main load cables are 2.5-3mm in thickness.
Maximum room size is about 14.5 metres. (range 8-14.4)
(105watts por m2)
Is this waming of the thermostat due to a cheap chinese brand? Thin cheap components?
Some are worse than others. Even found one with black burn marks on the plastic housing where the switch cables are routed!! Bypassed that immediately.
I don't fancy changing all 10 at 45-50 USD each.
Thanks in advance
(105watts por m2)
Thanks in advance
