Discuss Choc Bloc - Suitable for extending cable to light fitting? in the DIY Electrical Advice area at ElectriciansForums.net
danny199
Hi, I would like to move a light fitting and switch. The switch, about 20cm, the light fitting, about 60cm. I've been looking online and found a product call the choc bloc, would that be suitable for my needs? The cables are in the attic under the insulation material currently. Some previous work looks like it was extended with junction boxes in another room.
As above, and strain relief is also required.
Would this be suitable?
https://www.NoLinkingToThis/p/debox-in-line-connector-box/8692h
or
https://www.NoLinkingToThis/p/debox-2sl-screwless-in-line-junction-box/9858r
Thanks, should these be mounted to a joist etc? I've read in some places yes, no in others. I have an existing junction box in the loft and the electrician just left it on the top of the plasterboard and covered it with insulation when he added two more lights to one of the rooms, before we owned the house.
You should be able to pull through the amount of wire you are talking about?
Hi, no, sorry if I wasn't clear, I need to move the light in the ceiling to the middle of the room. There is not enough cable to do this, so i need to connect a bit. I was thinking of using one of those chocbox plastic box things but don't know if I need to secure it to the rafters.
If the box has cable clamps then that will prevent the cable moving and becoming loose so it’s not necessarily needed to secure the box but it’s not hard to do, so I’d personally fix it in place , above any insulation if possible.
Yes, the ones I'm looking at have the clamps to secure the cables and the terminal block sits in the middle.
As an aside, is it best practice to keep cables and junction boxes above the insulation. Might be a job, the previous owner installed about two foot of it up there!!!
If possible I would always fix above the insulation so it’s more accessible to find and being a screw terminal connection, it needs to be kept accessible for future inspection and testing.
Appreciate that it’s not always possible on existing wiring
I would think that logically but I might be hard pressed to do that in the current situation. Thanks for the guidance.
Hence the reason for me mentioning maintenance free connectors...
Sorry, just to check, the terminal connector I was thinking of using is 16amp, I believe this is suitable for a lighting cable extension?
the quickwire is maintenance free, no need for earth sleeve, easy fit in seconds. ÂŁ5 a pop. also has the facility of adding another light if required. .
Reply to Choc Bloc - Suitable for extending cable to light fitting? in the DIY Electrical Advice area at ElectriciansForums.net
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
Good afternoon guys, got a new light fitting, which is not supplied with the usual female terminals for wiring but rather has a short wire...
Hi all, I have a light in the under stairs cupboard which is controlled by a switch in the hall. The under stairs cupboard is being taken...
