Discuss Cost of CU swap out in the Business Related area at ElectriciansForums.net
lurch
Hi
I am hopefull of generating some work with a kitchen company. One of the areas there fitters wont touch is CU chnages. Typically what is the going rate you guys would charge? I am thinking in the region of £450.00 subject to survey and any additional works on top to bring the existing install up to scratch. This would include a 12 way split CU with 2 x 30ma RCDs, 10 MCB's and new 25mm tails.
My way of thinking is to charge time and materials on top of the swap out for any defects.
Let me know what you think . . . . cheers
Not far off i reckon.
You should also make the customer aware that faults and/or any non conformities if any, will need addressing at extra cost.
I start at £350.00
If main bonding is required & is easy to sort I include in the cost, if it's a little more involved then add £150.00
Any inherant faults with the installation are extras & priced accordingly.
quick question. . . . although I have said I would replace tails, if this is not done and they are already 25mm but red and black would this picked up by an assessment body?
Reply to Cost of CU swap out in the Business Related area at ElectriciansForums.net
Hi guys, I've gotten AI to write up a terms and conditions for my company and then went through it with AI and tweaked it to make it sound a...
Hi all Now being upfront I am not a sparks. I am about to have some work done by a friend (certified) and as he is doing me a favour I want to as...
Hello, this is my first post here. I have a little experience with most types of household wiring through a decade of DIY remodeling, and...
Hello, I have a Clipsal consumer unit with two "ways" unused and blanked off and potentially a third available as the Proteus Geyer B16 MCB is...
4K
Good morning all. I have scanned posts and haven't found the exact answers I am looking for so I'd like to ask for a bit of advice related to my...
5K
