Discuss CU change in cupboard under the stairs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
Miketwinny
i2.jpgHi
I want to change the old fuseboard in the cupboard under the stairs to a new CU.Would I need to reposition it to comply with part M build regs for easy access or would a straight swap be ok.
Just swap it where it is. If it were a new build then Part M would come into play. Consider providing an emergency light in the cupboard, easy enough to do and provides piece of mind.
Is it just me or should the grey L & N cables connected to the j/boxs after the isolator be the same size as the cables coming out of the isolator then only reduce down in size when they are fused to the relevent sizes? or is my eye sight going...
one would assume that OP would rectify that on a CU replacement.
most economy 7 supply cutouts often have 4mm double insulated tails coming straight from the henley blocks , no other protection for these conductors other than the 100A main fuse :)
DNO dont have to comply with out regs ! lol
although in this pic it does not seem those tails are associated with the supply company as they are after the main switch
the grey L & N cables connected to the j/boxs after the isolator go to an electric shower CU which will be made redundent.
Read more: http://www.electriciansforums.net/e...ange-cupboard-under-stairs.html#ixzz2LaLWuVGa
Reply to CU change in cupboard under the stairs in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi. I was asked to work on a loft conversion and a full refurbishment of a 5 bed house. The contractor said that as he is doing a loft...
Hi all, I have a light in the under stairs cupboard which is controlled by a switch in the hall. The under stairs cupboard is being taken...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
So a friend of mine has a new build (2020) typical new build lashed in. Hes getting an electric car soon however fitting a charger will be a pain...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
