DNS
I was asked to take a look at the storage heater that wasn't working, dual supply. Found that the On/off switch had burnt out,middle terminal. Replacement is easy for that componant, but the wire from the switch has obviously been hot and the insulation is brittle and fallen off about 10mm from the spade connector. I could just put some heat shrink or some insulation tape. BUT I would prefer to replace it and do it properly. Can any one recommend a suppliers that could supply this wire. Its only about 60 mm long with spade connectors each end.
Dimplex CXL range storage heater spares and parts
It's not shown on this diagram, maybe I should photograph it and send it to the suppliers.
Any suggestions, Thanks.
I don't think it's available as a single wire mate, only as part of the complete control wiring loom.
Contact these guys, they will be able to source and supply the genuine part if it's available:
Uk Electric Ltd, Votec House, Hambridge Lane, Newbury, RG14 5TN
Tel 01454 620500 Fax 01454 620660
www.uk-spares.com
Reactions: 1 person
Could try omega or RS for glass braid wire.
Reactions: 1 person
Dimplex cxl storage heater
Central Heating Systems
DNS,
Richard Burns,
