DNS
I was asked to take a look at the storage heater that wasn't working, dual supply. Found that the On/off switch had burnt out,middle terminal. Replacement is easy for that componant, but the wire from the switch has obviously been hot and the insulation is brittle and fallen off about 10mm from the spade connector. I could just put some heat shrink or some insulation tape. BUT I would prefer to replace it and do it properly. Can any one recommend a suppliers that could supply this wire. Its only about 60 mm long with spade connectors each end.
Dimplex CXL range storage heater spares and parts
It's not shown on this diagram, maybe I should photograph it and send it to the suppliers.
Any suggestions, Thanks.
