Discuss Dishwasher/Hob in the Electrical Appliances Forum area at ElectriciansForums.net
L
Lioned
A customer of mine has a small kitchen and wants me to fit a dishwasher in the unit below the hob.I am trying to think of a reason why not as its a bit unusual,but i cant think of any reason why not but would like opinions please.
Unusual it maybe, but i can't think why you can't comply with your customers request either. As it's a small kitchen, i guess any and all available space needs to be utilised to best use!!!
I was thinking that in many 'integrated appliances they supply a self adhesive foil to stick under the worktop above presumably to stop the rising heat damage,but then many ovens are installed under hob units so i would think the underside of any hob would be designed to deal with that.
Just never come accross it before and it will look a little unusual.
Will check the instructions for the hob though. Thanks.
The other reason for the foil is to stop water penetration of the underside of the worktop. Dishwashers can give off water vapour /steam in use or if the door is opened straight after it's finished. You may get condensation in the hob?
Reply to Dishwasher/Hob in the Electrical Appliances Forum area at ElectriciansForums.net
A friend of the family recently lost her husband to the big C so I need to be careful. Every small thing is sending her into tears so when her...
I wonder if any one can give me some advice. I live in a fairly new build house it's 11 years old. In our kitchen there is a fused spur switch on...
5K
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
