Discuss DIY Help! Damaged Quick Connect 2 same color wires one side, Black & White the other in the Auto Electrician Forum area at ElectriciansForums.net
mporch
A quick connect on the bottom of my farm tractor was snagged by a limb and one side of the connectors wires were pulled free from the housing. The good side with the wires still connected has a black wire (hot?) and a white wire (neutral?) but the 2 wires that were pulled free from the other end are colored the same, both brown with a blue stripe. Does it matter which brown/blue stripe wire gets connected to the black or white wire? If so, how would I determine which one to connect?
Are you saying that you dug up the power company’s wire or your own wire?
Reply to DIY Help! Damaged Quick Connect 2 same color wires one side, Black & White the other in the Auto Electrician Forum area at ElectriciansForums.net
Hi All, I have a terminal on the wall with 2 blue wires, 2 brown and a copper one (Photo 1), and I would like to connect a lamp which has 1 black...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
A simple outlet, 110v a single (2) outlets on the left side of the box, a spst switch on the right, with a single cover, covering them both. The...
New fan with light - and remote. Wiring in first pic from manual. Black, brown, blue, white. Second pic - my light fixture pulled down with wires...
