Discuss DIY how to wire new circuit breaker to new switch and recessed LED lights? in the DIY Electrical Advice area at ElectriciansForums.net
Mannyv777
I recently installed a new 15amp circuit breaker, and wired a 14-2 gauge wire to a brand new dimmer switch. From the dimmer switch I daisy chain wired 6 LED recessed lights. When I turned on the circuit breaker the lights all turned on, but the switch wasn't working. I then changed the switch to a different configuration that uses the 3 wires only, the lights would turn on, but when I'd go to flick it off the breaker would trip., I exchanged different switches and same issue. Install a regular switch no dimmer and same issue. It'll trip my breaker when I'd go to switch it off. What am I doing wrong??
Reply to DIY how to wire new circuit breaker to new switch and recessed LED lights? in the DIY Electrical Advice area at ElectriciansForums.net
our dimmer switch stopped working after 7 years so went to replace it at the weekend. When I opened it up, the black wire was in the common slot...
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently...
We have one room that seems to have lost most of its power last night. One of the outlets in the rooms has a power strip plugged in that powers...
After 24 years my septic lift station pump and high water alarm needs to be replaced. It was tripping the breaker and the alarm was no longer...
Hi, I was ironing and lost power to the bedroom and bathroom. All outlets and lights. I checked the box and reset breakers still no power. I...
