Discuss ebay LED floodlight AC on DC? in the DIY Electrical Advice area at ElectriciansForums.net
Don't want to sound disparaging, but you should read the advert before you buy, lecture over sorry mate
All you can do is try it. If it works great if not you've learnt a lesson about buying from fleabay.
there is nothing wrong with buying on ebay.
quite often i make it a point to research items from the manufacturers sites before i purchase from ebay
quite often i find info that's missing in the descriptions.
most sellers are pretty good about getting relevant info but you cant expect perfection.
by the way an led is a diode (passes current in one direction and blocks it in reverse)
in short it converts an ac voltage to a pulsating dc voltage.
most lights of this type have regulating circuitry in them
They will run on DC or AC.......only problem is, on AC polarity does not matter, with dc polarity does, so you will need to identify which is the positive lead
That may be the case with an individual LED, but I would be surprised if this light didn't contain an up-front rectifier, followed by a constant current driver (seeing as the stated supply voltage is 12 to 15V AC). In which case, supply polarity won't matter. I think that there's a fair chance that it'll work OK.
Reply to ebay LED floodlight AC on DC? in the DIY Electrical Advice area at ElectriciansForums.net
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
Good afternoon! I've recently wired a lighting system, where one light switch (a motion sensor) turns on two lights, but another motion sensor...
I have garden LED light running fine through a transformer.. LED Driver Adapter AC 220 -240V To DC 12V Transformer But am now trying to add a...
6K
Hi guys, Im looking at fitting a floodlight in my back garden. It is a 30w LED with PIR sensor (bought from Toolstation). Ideally, I want the PIR...
Hi, I need to replace some kitchen lights that take G4 pin bulbs. I'd like to switch to LEDs but not sure if the transformer fitted will be too...
