Discuss Electric shock from outdoor security cameras in the UK Electrical Forum area at ElectriciansForums.net
Hi there. I just bought this outdoor security camera kit from Amazon.
https://www.amazon.co.uk/gp/product/B00WLJ38DO/ref=oh_aui_detailpage_o09_s01?ie=UTF8&psc=1
When wiring it up, I noticed that I got a small sharp shock when touching the small screws on the metal casing around the cameras. I was wondering if this should be considered dangerous, or is this perhaps just static electricity?
The cameras are powered by a standard looking 12V power adapter.
I've added a photograph of the rating on the adapter here:
https://s3-eu-west-1.amazonaws.com/sifjskdjfkasdjflsda/camera_power_adapter.jpeg
Could something else be causing the shock. I fed the cables through an existing hold in the wall so they sit along side an existing power supply for outside lights. I wonder if this could be causing an issue.
Thanks!
Dave.
Did you drill through this existing cable when you screwed the camera to the wall?
As suggested, its probably static. If its just a short crack, and no lasting effects.
Is the outside light on all the time(to feed a PIR), or only when a switch is pressed? It may be an induced current, but unlikely.
You can prove it's not static (which is generated by you moving around and then discharged to a metal object) by discharging yourself to something else e.g. a radiator. Installed equipment does not normally generate static. I suspect it is leakage current:
The power supply unit (PSU) is double-insulated, i.e. does not have an earth connection. In normal operation there is often a small amount of leakage current from the electronics inside the PSU, typically a few tenths of a milliamp, that finds its way to the 12V output side as it cannot otherwise be discharged to earth. Although the leakage current is tiny, it originates from the mains input side and can reach a high enough voltage to be felt.
Cheap PSUs and ones that do not fully meet EU safety specifications can have unpredictable leakage levels, but even good quality units still produce some leakage that can be felt as a 'vibration' when a flat metal part of the connected equipment is stroked with the back of the hand.
If there is a PSU for each camera, and all cameras are connected together via the video cables to the DVR, any point you touch will discharge the total leakage of all the PSUs, which you will probably feel.
If this is the cause, it is harmless and safe, but without an actual measurement using a PAT tester or similar, it's impossible to say whether the PSU is faulty or not.
Reply to Electric shock from outdoor security cameras in the UK Electrical Forum area at ElectriciansForums.net
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Hi, I purchased a Time twin strand bell cable with a rating of 12-30V, 2A, low voltage, not for mains use. I wish to use this for installing our...
So I kinda want this: meross Smart Power Strip, 6 AC Outlets + 4 USB Ports Smart Extension Lead, Compatible with Apple HomeKit, SmartThings...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
Just received a Eufy CCTV floodlight camera (This one) which requires existing wiring. We have two outdoor lights on the side of our house with a...
