thanks for the response , tried looking for a fine toothed narrow blade for multitool , but cant seem to find anything suitable.
There are metal blades for multi-tools and I missed that off the list. In my opinion it would be quite hard to multitool a large circle as the material will be vibrating like mad and you'd have no easy way to counter this.
On a serious note, depending on how thick the material is that you need to cut, maybe a Dremel could work?
Of course, I notice that no-one has yet suggested doing it the old way with a stitch drill.....
I thought stitch drilling is the same as "using a smaller hole saw multiple times", or is there something handy to learn here?
Decent quality holesaws are available in 160mm for much more reasonable prices, but you stand a good chance of pulling the gearbox out of a drill or breaking a wrist using them to cut sheet steel.
Nibbler by far the best option.
Good old fashioned adjustable tank cutter. These were used for cutting holes in steel water tanks, and mine probably dates back to the '50s, but they are still available new.
They need a well located pilot hole, so you'd have to 'fill' the original hole first. This could be a 100mm long piece of thin steel bar, pop riveted across each hole in turn.
