Discuss Fire alarm sounder connected to door entry system help please in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
R
Ross Harvey
Hi All
I have door entry system that i installed at a care home. it is a fail safe system but they didnt ask me to coonect to fire alarm system unitl after i had second fixed it all.
Long story short i have connected it (through a relay) to a local fire alarm sounder that gives out 24v on alarm conditions.
This works correctly but the fire panel shows a fault on the sounder system. Is there an easy fix? Maybe connecting a resistor? any help would be appreciated.
I'm no expert on fire alarms systems by any means, but there are usually outputs on the panel PCB to connect to for things like this.
Someone will be able to set you right soon I reckon.
Thanks for your reply.
The reason i have connected to a local sounder is that the fire panel is the other side of the building and not easily wired back from.
maybe a blocking diode would get you out of trouble. however, it's not recommended to modify any fire alarm system without thoroughly considering the implications of failure to operate in case of a fire.
yep. it conducts d.c. one way with a 0.6 volt drop, but blocks the other way. the diode used is selected according to the current requirement. not sure if it will cure your problem though.
How would i connect that diode? across the positive and neg going to my relay or just on the positive out in series? and would it also stop the relay from operating?
personally i wouldnt be messing around with a fire alarm in an old folks home
well risky if something goes wrong
lnstall a stand alone sounder
As tel mentioned a diode will do the job, however it isn't the right way and will need to be a very temporary fix, Tazz where are you ??
Connecting any release or shutdown to the sounder circuit, is a breach of regs......reason being, the doors will relock when system is silenced....and must only relock when the system is fully reset. All release, shutdowns must be off panel fire relay, or addressable output unit.
Example, fire alarm activates in nursing home, doors release, then staff member silences system while evacuating...doors relock trapping residence in building
Reply to Fire alarm sounder connected to door entry system help please in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
I'm installing mag-locks and fire door hold-open magnets at the moment and I'm wondering if any of the cable should be fire performance cable...
I am doing renovation to a cafe in Scotland at the moment and after speaking to the local council the building requires the minimum standard for a...
Hi I’m after some advice please I understanding a fire alarm system. I get how the conventional and addressable are wired. By my question is about...
