- Jan 4, 2011
- 397
- 320
- 101,238
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
Hi all, Does anybody have a link to a guide for retro fitting downlights to an existing ceiling? the main point being assessment as to whether fire rated fittings are required. Obviously the belt & braces approach is best ie fit fire rated regardless but occasionally there are other factors such as oversized holes already in the ceiling or a particular request by client etc . Also do any of part B's (?) requirements apply to existing ceilings etc anyway? cheers John
