Discuss fixed appliance testing in the UK Electrical Forum area at ElectriciansForums.net
C
craigday
hi guys, I've been asked to carry out a fixed appliance test" on equipment in a warehouse, such as cooker(industrial), and such things like loading bay lift which is wired into a isolator, and other hardwired equipment now do I need a special tester, like a pat tester or am I being really stupid here? any help would be appreciated, thanks
Nothing to stop you using a PAT tester.
one of these will help.:
The loading bay lift will need a little more than a pat test or MFT ... a ramp/lift service engineer is the one to be issuing a clean bill of health and safety for this equipment. Be vary careful if testing anything you are not accustomed to as their control systems may be sensitive with plc's, circuit boards, timers etc their is nothing wrong with checking larger equipment but know your limitations.
I get the hoists, lift ramps and similar equipment service tested yearly who confirms it meets relevant BS regulations for the equipment and as this falls outside the BS7671 you need to ensure your customer is aware this is not an official cert' of safety and compliance and requires competent persons to inspect such equipment. This is beyond you canteen kettle and fixed storage heater etc ....
Reply to fixed appliance testing in the UK Electrical Forum area at ElectriciansForums.net
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
Hi all Some advice on this would be great. Due to wire a kitchen from scratch and in a pickle over the designing of the oven and hob circuits due...
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
