Discuss Fuse too big on fridge in the UK Electrical Forum area at ElectriciansForums.net
I look at Wagos on a regular basis when I’m installing them. They’re still a single point in a circuit.It was amazing how many could not figure that out, which was so simple. You need to look at Wagos.
No reg says local isolation is needed.
You should work to your electrical training and knowledge, not be like one of these, rear end covering, moronic, reg followers.
Show me the reg that says local isolation is mandatory? Whatever local isolation is of course. Where should this non-mandatory local isolation be? in a cupboard? Over a worktop? In an adjacent utility room? Under an appliance? Where?
Amongst others.Oh no. Tell me it isn't! Not the same person who was putting forward the argument that Wagos are more of a busbar than screw terminal junction boxes???
Amongst others.
A sole appliance, on a radial, drawing a third of an amp, on 1.00mm cable on say a 10A mcb is electrically sound and safe. Are you saying it is not?We are talking about you saying that 1mm is 'electrically correct' for the circuit. Don't try and change the subject because you are wrong and know it mate. Have a look at the table I mentioned in a previous post for the reg.
Er, no. Look again.I look at Wagos on a regular basis when I’m installing them. They’re still a single point in a circuit.
You are supposed to be electrically trained. To think. Now do not look at table. Tell me where it is electrically not sound or safe? I will be waiting a long time.We are talking about you saying that 1mm is 'electrically correct' for the circuit. Don't try and change the subject because you are wrong and know it mate. Have a look at the table I mentioned in a previous post for the reg.
Understand what a bus bar is then look at a Wago.Oh no. Tell me it isn't! Not the same person who was putting forward the argument that Wagos are more of a busbar than screw terminal junction boxes???
Clearly whoever they are this person possesses more intelligence and common sense than the rest of us, not to mention the persons making up the JPEL/64 committee. It’d be easier if we all just bow down to the superiority of their arguments and accept their word as truth instead of following the clearly illogical and inferior regulations that have gotten us to this point...I understood it last time. Gave up trying to argue though. You wouldn't listen to anyone elses opinion.
Is this the Pickhill Bantam welder thread?Just chop the end off a 9" nail and shove it in the plug top's fuse holder. Job done.
A reg quoter again. Lokks like someone who has been trained. I told you not to look at regs, then assess, then tell me where it is not electrically sound and not safe. I am still waiting.Again mate, don't change the subject. I did not mention 'safe' in any of my posts.
Quoting you: "1.00mm would not be electrically incorrect." Post #69.
This is incorrect. 1.00mm is electrically incorrect. Look at the regs.
Reply to Fuse too big on fridge in the UK Electrical Forum area at ElectriciansForums.net
