Discuss Future Replacements of Solar PV components - what happens if.... ? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
danesol
Thinking ahead...............In the future should say your panels or Inverter fail, what do the rules & regulations say as to what you can replace with in the event of NOT been able to replace with exactly the same items ??
I asked the same question on my C&G2399 course and the lecturer just said a compatible part so in 15 years you could end up with a 300x300 panel in place of one of your 1680x900 panels. Hmmm. If that was the case I think I'd stump up the extra and change the lot, especially if it was 15 or 20 years down the road.
Inverter wouldn't be such an issue though.
As long as you dont increase your declared net capacity (kw) ?? :wink_smile::wink_smile::wink_smile:
What happens if say 2 panels go down in 5 years time. Assuming the manufacturer is still around and honours the warranty, what if they no longer make the same panel? Can you substititue with different panels with different specs?
The other thing I was thinking about, If a single panel fails does this cause the whole array to stop functioning?
Different brands of panels run with different volts or amps.
However, an array with two strings could have one string replaced with new panels and the other old-but-functional panels used as spares for the other array. One day there could be quite a market in "used" solar panels of commonly-installed makes.
Or convert one string to two strings and use a dual-input inverter, or add a smaller inverter for the new string of replacement panels.
In fairness, the inverter is far more likely to malfunction than the panels.
I reckon that about half of all inverters will have failed by the time the system has reached half of its lifespan (13 years) and probably almost every inverter will be replaced/repaired at least once during the 25-year FiT timeframe. A few will be lucky and boast at how their inverter lasted the whole 25 years. Others will grumble becuase they were unlucky and had to replace the inverter two or three times.
As for the panels: I'd guess that less than half of the arrays out there will need any panels replacing during the lifespan of the system as the panels will probably degrade slowly rather than fail catastrophically. Of course, the panels may declinine in output as they age, due to occasional single-cell or failures or subsections of a panel - mostly suffering from a damaged connection due to weathering (hot/cold/wet/wind-stress etc).
But even if I lose a section of a panel, it'll not be a major influence on the whole system due to bypass diodes.
My panels are 6 rows of 10 cells, with every two rows being served by a bypass diode.
I have 15 panels.
That's 900 cells in 45 groups of 20 cells.
If I lose one group of 20 cells, it is about a 2.2% drop in output. From 3.6kW to 3.52kW.
Many manufacturers guarantee their panels to perform to 90% after ten years and 80% after 25 years. While we can't measure it exactly, we could certainly tell if the panels had degraded at twice that rate, but even if they did degrade twice as fast as expected, the FiT returns from the system would still be attractive.
At 21p and a cost of a £8500, 3.6kW system, total earnings (FiT, export tariff and bill savings, assuming 3% inflation and 3% energy price rises)
(20% loss of performance) 80% of performance after 25 years: £18300
(30% loss of performance) 70% of performance after 25 years: £17700
(40% loss of performance) 60% performance after 25 years: £17000
Chances are, that as time passes, the cost will continue to come down.
Look at today's biscuit-sized MP3 players compared to the book-sized, tape-playing "Walkman" of the 1980's. The cost and performance of a MP3 is dramatically superior to the Walkman. Solar technology will probably dramatically improve too, over the rest of our lifetimes
Reply to Future Replacements of Solar PV components - what happens if.... ? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hello, My current 2.5kW Solar pv array is in a less than favourable position, but there is plenty of space to expand the array. I have an...
My best mate has been medically retired from the prison service at the young age of 52 and has time on his hands :D He's looking at a 'plug in'...
Hi, So I'm replacing a small old off grid with a new 7.5kw off grid, & being poor seek best value for my mppt, after long searches I find this...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
I decided to get solar panels, the inverter instructions say one can use type AC, so the existing 14 x RCBO CU seems OK, may be a good idea to fit...
