OP
- Reaction score
- 1
Ok, that makes sense. So basically I need to check if my gen's output is L1=L2=110V for me to be able to use an autotransformer.If one end of the output is internally grounded (i.e. connected to the frame, ground terminal or receptacle ground prong) then a continuity test will reveal this by a very low resistance (<0.2 ohms) from the neutral / 0v side to that point. You will also see a low (but not as low) resistance from the hot (230V) side via the generator windings. In this case you cannot use an autotransformer to create a grounded centre-tap, because two points at different voltages would then be grounded and hence connected together.
Are you saying that if my gen's output is L1=230V and L2=0V (internally grounded), a two-windings transformer will work to get a neutral and solve my 110V problem? Can you explain how as I'm confused by how this would work. If there's a schematic diagram out in the Internet that you know explains this, please link me to it.An isolating transformer (with separate primary and secondary windings) would be OK as there would no longer be any connection between the generator output and the panel.
Ok, this makes complete sense. I was wondering about the hot, neutral, ground terminologies for floating outputs.If the output is floating you will read no continuity from either side to the frame / terminal / ground prong. This is by far the more common arrangement for mobile / portable generators. Although the two wires of the output might be called 'hot' and 'neutral' and coloured to match, if neither is grounded there is no hot or neutral as there is no defined voltage to ground; they are just two wires forming a circuit.
If you ground one of them, you force it to 0V with respect to ground, so it becomes the neutral, and as the other is 230V from it, and hence now 230V from ground, it becomes the hot. If instead you ground an artificial centre-tap to make that the neutral, you force both output terminals of the generator to 115V with respect to ground, so they both become hots.
