Discuss Hello clever people. I want to know about 'volt sticks' in the Australia area at ElectriciansForums.net
They're good for checking for a voltage where you can't get to a terminal, (eg a cable) but shouldn't be used to replace safe isolation.
There was a post earlier about an electric shock being recieved because someone had stolen electricity from a flat landing. If the main fuse is pulled then you would hope the electrical installation was dead.
The OP mentioned in his post about testing each outlet. I would hope that you really do not need to do that once the main fuse is pulled. But, stolen electricity is an example of when things can go wrong.
That post opened my eyes. Anything is possible.
This might be where the volt-stick could be a very useful tool.
Before you touch anything you use your 'volt-stick'.
Then you check again.
Does any know of a quality volt-stick?
the ones that light up art the end are best
sorry, mate, couldn't resist that. best iv'e used is a fluke with a notch in the end. tells which cable is live in a grope oops, group
Giggle...
I was just wondering Telectrix........do you live in a zoo?
that's our fire ice bearded dragon, not to be confused with the mother in law. the former is a pet and the latter eats live locusts
A volt stick or voltage indicator picks up electric magnetic fields present with current that operates an internal switch to send power from the battery to the led to show that electricity is present. That also includes static electricity and magnetic fields from other sources so it should not be relied upon solely before working on that circuit.
oh, paul, you,ve ruined everything now. i thought it was magic. and santa has one
Well if Santa has one I hope he's part p qualified to use it :):)
Next week children we will be discussing Ohm meters. (note to self, get out more)
can't we start with ohm sticks before we progress to ohm meters
Reply to Hello clever people. I want to know about 'volt sticks' in the Australia area at ElectriciansForums.net
Question about the Definition of #6 wiring standards for Thailand as of 2023? I am having a House/Villa built in Thailand and I wanted to wire...
hello all. I am trying to add led strip lights to my boat trailer. I have marine grade submersible lights. I will have them running parallel to...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
CityElectricalSupply.com (CES) are an electrical supplier across the United States with over 550 branches coast to coast. Here in the UK we...
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
