Discuss help needed with non standard heating system in the Central Heating Systems area at ElectriciansForums.net
C
cruelty
hi,
system has CH & HW Zones
system also has back bolier
system has no motorized valves
so there is 2 zone time clock
1 room stat
1 cylinder stat
1 pipe stat (on back boiler flow pipe)
what i need to happen:
CH turned on = fire Boiler & Circulating pump
HW turned on = fire Just boiler
Back boiler flow pipe = fire just circulating pump
cant seem to understand how to connect without getting back feeds etc..
any help appreciated
I'm a little confused by your mention of back feeds, what type of boiler is in use (does it have separate HW and CH outputs?).
What is the back boiler feeding, HW, CH or both? I'm guessing both and you have a two coil storage cylinder? I'm off to bed, but it may help someone else answer.
its an oil boiler with pump beside it (located in garage)
back boiler it to be used for CH & HW and yes its a 2 coil storage cylinder
thanks for your reply, any help appreciated as i need to complete job in few days :thumbs_down:
OK, if I can summarise you have:
1 x two channel programmer (CH ON, HW ON, HW OFF)
1 x room stat
1 x cylinder stat
1 x pipe stat (on back boiler flow pipe)
You have no motorised valves so you may only have one CH zone.
Do you have separate pumps for the back boiler and main boiler or only one pump ?
When you refer to the 'back boiler' is this a solid fuel stove arrangement where the oil boiler is used to top up the system if the back boiler isn't able to meet demand? A little more detail about how it's plumbed in would be helpful i think. If the HW tank has two coils is the oil fired boiler only connected up to one coil and no CH loop? At the moment i can't make a lot of sense of what you want to achieve. I'm assuming it's a gravity hot water system with pumped central heating?
as i am only doing electrical side of things i am not up to speed on the plumbing end of it
@topquark: yes you are correct on:
1 x room stat
1 x cylinder stat
and yes i have only one CH Zone
there is a separate pump for back boiler
@Dunc: Back boiler is an open fire with flow and return pipes, and yes oil should be used to topup demand, i will find out more from plumber tomorrow and post it up
I do know its a pressurised system
thanks
OK so far, then the component list is correct (and piccy), we now need to know how the back boiler is connected into the system (to decide how to wire the pipe stat in).
hey, what do you mean by how the back boiler is connected to the system? do you mean plumbing wise or electrical?
Plumbing wise. It would be useful if you (or the plumber) could draw a flow picture of the plumbing and indicate on it where the two pumps and two heat sources (back boiler and oil fired) are.
i will try and explain to you now, because wont get talking to plumber until Monday :(
back boiler (open fire) located living room, flow and return from cylinder, pump located in hot press
Circulation pump for CH in hot press also beside cylinder which is just flow and return from cylinder
Oil Burner and pump located in garage and also a flow and return
how that helps but could be no use at all lol
EDIT: Plumber has agreed to fit motorized valve after circulation pump so i can switch it for HW or CH (ie. boiler & c.pump for CH, - boiler only for HW)
So its a standard "C" Plan at the minute
So how to add back boiler to system, knew i would get it in the end lol
thanks for your patience
under no circumstances should a solid fuel fire be connected to an unvented pressureised system and even if it is unvented yuo ned a flow divertor
Reply to help needed with non standard heating system in the Central Heating Systems area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hello, I hope you are well, I have fitted a few Nests but only to Combi, S and Y plan systems just been looking a job where I’m doing the kitchen...
I have a fully pumped Y plan heating system using a Potterton EP2 programmer. Drayton MA1 Diverter valve. I have just replaced the Actuator head...
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
