J
joebb
Hi I have wired an emergency lighting circuit on a staircase and want to know the connections for the key switch, I have taken a 3 core t&e from the first light to the switch which is next to the normal switch, I have not gone to the switch with the main feed first so no neutral at switches.:confused: please HELP.
2 gang box feed to em , em out to common on 1 gang switch/ p/live to em fitting L1 to switched live on fitting
Why the T&E
all your keyswitch does is interrupt the permanent live to the EM., so the keyswitch is N/C.
HELP on EM key switch
Australia
joebb,
bugsy,
