Discuss Help with potentially bonding a metal roof (lightning protection) in the UK Electrical Forum area at ElectriciansForums.net
J
jjnr78
Morning. I'm on a new build project where I have 3 houses (2 semi-detached, 1 detached) which have these really funky metal roofs. Its a modern design and the cladding literally starts at ground level on one side of the building and wraps it way over to the opposite side of the building (or neighbours in the case of the semis). You can therefore directly touch this stuff. Oh and there will be a couple of wall light fittings installed to it.
The manufacturer (Standing Seam Roof | Roofing Solution | Colorcoat Urban®) and roofing contractor have taken months to get back to me regarding earthing and even then they have been non committal and very woolly. The houses are standard height structures and this metal roof is not completely continuous. Ib guess I'm trying to gauge where this sits with the regulations for lightning protection, which I have never worked on. My thoughts were to test it for extraneous metal work and start bonding where necessary.
If it is a complicated issue I might be best placed to hand it over to a specialist. If that's the case, who knows a competent engineer in the Herts/ N London area?
As has been stated, that unless these 3 houses are going to be vulnerable to lightning strikes by their location and/or in respect to the situation of other buildings in the vicinity then it's unlikely you'll need to worry about LP systems!!
I did check on the company's web site, and as you say, the information afforded as far as L/Protection is basically useless and looks like it's just a cut and paste job. Strange as TATA is a Southeast Asian company (seems to be trying to hide that fact on the UK web site) and as such should be well versed in LP requirements, seeing as this part of the world has one of the highest annual strike factors in the world!!. It's main Head Office is in Singapore...
and i thought it was good old blighty:
Reply to Help with potentially bonding a metal roof (lightning protection) in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys, I'm looking for some opinions, I've got a customer with a gas meter in an in ground box (see picture). The pipe to the meter is plastic...
5K
HI all, I need to bond metal stud work on new build houses, 4mm from socket to an upright, uprights have roof baton for noggins, then socket...
4K
Good morning everyone. I’m looking at getting an EV charger installed at my home and the company is requesting that I earth bond my water supply...
4K
Background Two weeks ago, lightning struck a tree in our yard. Many circuits tripped and several electronic devices failed. There was a strong...
