Discuss Home automation advice needed in the Australia area at ElectriciansForums.net
335-pilot
Hi,
I have been given the task of installing an automated light and heating system into a new build timber frame house. It is to have a fair sized plant room as well as swimming pool and cinema.
I have never had to contemplate anything on this scale before so any contacts or suppliers etc would be most helpful
Electrical Contracting News has a feature article on a specialist in home automation company in the current edition, i tried to pull it from the bin but no luck, i didnt actually read it, but may be a starting point.
did a hnc project on home automation so will see if i can dig something out
Hi,
your out your depth to be honest
What ever you do with Home Automation Double it for ruture expansion and control as it is expanding at a rate of knots and by time you have finished the project there will be other stuff that can be controled,other ways to control it
335-pilot,
pm me and I will send you that business project, it may provide some useful info etc, but like alarm man mentioned, not to be taken lightly
Start by getting a detailed list of requirements for the overal system and getting that agreed with the client. As has been mentioned the biggest problem with these types of jobs is scope creep.
Reply to Home automation advice needed in the Australia area at ElectriciansForums.net
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Installed a new ceiling fan, with no previous light or power. There is a switch in the room that controls an outlet. I am trying to draw power...
Hi Question for all those who can help, the dreaded bedbug has appeared from neighboring property infestation, was planning to heat treat each...
Basic question to see if what I wish to do is correct: Client wants to build (or is building) and outside room (roughly 8m by 4m) to be used as a...
Hi I don’t know how resolve this so any helpful advice would be greatly appreciated. I have no electrical knowledge. I will try to be as clear...
11K
