Discuss horstmann economy 7 timer not working in the DIY Electrical Advice area at ElectriciansForums.net
A
akprincehbd
hi,
yesterday I just noticed my horstmann economy 7 timer not working... I tried the boost (1 hour) button, it still can light up on the indicator and heat up the water tank. However, when I used the Timed dial to set the time, I turned the dial a whole circle it won't heat up the water also the 'timed' indicator won't light up. the switch is not in 'off' position
I'm sure before I was using the timed dial in the day time and it also works, even it's in the day time, when I turned the timer dial, align 2am with the winter marker, the 'timed' indicator will light up. but now no matter how I turn it , it won't light up, the boost function works fine...
does anyone know what's the problem inside?
I have other concern, I was using all day same price tariff. but the elec power company said will switch me to the night cheap (E7) tariff at some point. Is it because they change the tariff?
thanks for your reply !!
you need a meter or voltage tester to see of you have power in and power out of the timer. the terminals are ( or should be ) live, so care needs to be taken when doing this. might be better to get an electrician to it. not an expensive job.
hi,
Horstmann E7's are run on an single unrestricted circuit and not from your off peak (it runs in the off peak period on its own timer). You have proved power to unit by the fact that boost works. Based on what you have said it could be either the Timed/Off Switch or internal microswitch that has failed. You will need to isolate and then prove these switches and associated wiring which are in series upto the point of the heater terminations to determine where the fault is. If you are not confident in this, then get an electrician. As Telectrix has already said, it is a simple job.
thanks
OK, I will give a go first
Reply to horstmann economy 7 timer not working in the DIY Electrical Advice area at ElectriciansForums.net
The unit only heats water using the programmed boost and when pressed in the 1 2 or Cont boost function. I have checked the off-peak time which...
Hi, My hot water hasn’t been working properly since beginning of Jan, only working when I press the boost mode for an hour. I had a new timer...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Yesterday moved my Mum into her new bungalow. The Hortsmann had been off for a few months I suspect. The boost worked, but nothing happened...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
