Discuss hot shower swtch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
S
steve.l
Hi , the switch to my shower gets very hot after the shower has been running for around 3 minutes .The shower was fitted about a year ago and has been fine up to now, the wires in the swutc are all in place and tight.. thanks
what's the rating of the shower and the switch? could just be cheap switch.
thanks for the very quick response , im not sure of the rating sorry ,im not at the house right now to check, i had a electrician do the wiring.
If the switch is getting hot then there is a problem. Get the sparky who wired it back to check it out, chances are it will get worse over time, not better.
Hi, get the switch replaced with a crabtree 50a switch, they are very highly recommended and have lots of wiring space .
Kind regards,
Decolad69
Ok thanks for all your help, i will get more info on the matter and get back to you. The shower is not being used at all . It is my daughter in-laws house thats why i dont know much.... thanks again
if it's to the south or west side of manchester, i can sort it for the sake of a call-out fee + any materials needed.
I have the same problem in one of my en-suites. 8.5kW, 6.0mm2, C32A, no insulation, DP switch, tight connections, hot totty when I touch it - crap switch !
I'll upgrade it when I can find a decent spark, - lol
Reply to hot shower swtch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
90s house electric issues continues 🥲 So after getting some good advice here I've managed to sort out some of the heating issues so thank you...
Hi, I have a client with a small caravan site, approx 5 hookups. His old toilet block was nothing much more than an old shed. He's now 'upgraded'...
Good evening all, I’m currently part way through my apprenticeship and we are working on IB, IN, IZ and IT and volt drop today. And it got me...
Hi, The shower pull chord switch has snapped at my mom’s home and having unscrewed the switch I discovered a horror show(see pic). So I’ve had...
Hello, I'm not an electrician, more one of those 'competent DIYers', so probably the worst kind :) My electric shower broke, the shower firm came...
