Discuss How to connect snap switch to this fan? in the DIY Electrical Advice area at ElectriciansForums.net
Basically i have this 12v volt that goes on car battery, it has a speed controller that goes from 0 to like 50000 rpm if you turn it to the right. Red/black cable goes to the car 12v battery, and the controller switch is controlled by 3 tiny cables red/black/white.
I want to solder a snap controller switch so it can spin at max rpm when i press on the controller switch. I have no experience in elektronics, can somebody help me out please how i need to solder the controller switch to make it work.
Here is a screen of a snap switch:
Hi - why not set the controller to the speed you want, then use a switch in the supply lead to turn the whole thing on / off ? Do you know the current draw? It's just that switch is for AC may not last long switching DC.
here's the diagram of the fan the fan uses 24 amps max, i believe the controller is like 12volt but i don't know how many amps it needs. So you suggest to snip the small speed controller cable (red/black/white) and wire a snap switch in between. It sounds good enough for me, do you have any idea which cable colors i need to wire on the snap switch?
And would a 3 amp 12volt snap switch be enough?
Reply to How to connect snap switch to this fan? in the DIY Electrical Advice area at ElectriciansForums.net
Looking for counsel / guidance to replace an original Dayton On/off with speed control switch. I’ve checked with a couple local electrical supply...
I am installing a ceiling fan in a newly built home. The builders have left the wiring for this purpose. In the electrical box on the ceiling I...
L
WIRING FOR WALL SMART SWITCH FOR CEILING FAN/LIGHT Just bought a smart wall switch for a ceiling fan/light currently connected to a single switch...
littletwinn
L
Im trying to make a Star Wars Prop for a course project where the dealine is comming up very fast in days and I need to do the report so really...
