Discuss How to hardware Cat 6 easy way ?? in the UK Electrical Forum area at ElectriciansForums.net
Installation of 7x cat 6 outlets in barn conversion at mains end what do i need to connect them up to router. Not my usual type of work so need a bit of help with what hard ware to buy can make sockets off just need help with the rest patch leads ect.
You have several choices. Either terminate them in a patch panel or if it's only 7, use two 4 way modular face plates. Then use patch leads to connect to the router (probably will have a four way switch built in).
If you need to use all 7, then get an 8 port network switch. Use one port to connect to the router and then use the other 7 for patch leads to the outlets.
Hope that helps :)
Reply to How to hardware Cat 6 easy way ?? in the UK Electrical Forum area at ElectriciansForums.net
I'm fitting one of the Apex 7S units on Friday. I'd avoided the original range after a couple of bad experiences but I figured a new model might...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
Good morning. Needed some advice please. I am getting an AC condenser unit installed on an outer bedroom wall but only after some internal...
