SnakeJerky
- Reaction score
- 0
Im making a led array out of 8 100 watt led's and I want to put something in between my battery pack and the array that can adjust the voltage coming from the battery and also shows the voltage. I was wondering if someone could help me find something that can withstand the power demands the led's have. It it needs to withstand at least 800 watts 36v and 30 amps. As a power supply I'm using two 18v Makita battery's in series
I wanted to use something like this but I cant seem to find one that can withstand the right power demands
UCTRONICS DC 6-30V to 0-36V 6A Variable Voltage Power Supply, 9V 12V 24V 36V Constant Voltage Current Stabilized Regulator Module, Portable Adjustable Buck Boost Converter Bench
UCTRONICS DC 6-30V to 0-36V 6A Variable Voltage Power Supply, 9V 12V 24V 36V Constant Voltage Current Stabilized Regulator Module, Portable Adjustable Buck Boost Converter Bench Item Description UCTRONICS U6234 is a 216W DC buck-boost converter and stabi
www.uctronics.com
