Discuss In your country, do you use pipe to run wire through very much? in the UK Electrical Forum area at ElectriciansForums.net
From a good practice point of view the trench should have been blinded with a concrete layer or clayboard to lay the reinforcement/ducts on, this would prevent the concrete from being contaminated by stones and earth kicked up when the concrete is poured into the formwork, the stones and earth can facilitate a path for moisture and rusts the reinforcement this in turn expands and breaks open the concrete (concrete cancer) at best or the ducts at worst.
I think the duct bank will be good for 100 years or better. But your welcome to take that up with an architect.
Normally I see a footer or concrete wall for a building; whether pre cast or otherwise, it's filled back in with dirt around it.
You have not understood my post, try reading it again.
I don't see how rock or earth will get in the concrete as it's poured. It gets pushed out by concrete, not mixed in. In fact some concrete have aggregate added for strength, which is essentially rocks.
As I explained previously, we were required to put 1.5" thick block under the interlocking plastic spacers that the conduit is set in. So now, with the spacers holding the PVC above the earth by 2 or 3", & the block another 1.5", there is a gap of 3.5" of concrete under the PVC.
Well you can go against the perceived wisdom of every Structural Engineer and carry on thinking that way, it's up to you, but don't try and get a job as a Ground Works Engineer.
As I said before, this was how it was engineered. There was a detail in the prints that laid it out as such. So apparently, I'm not the only one going against your 'percieved wisdom'. The ONLY difference was the engineer wanted it raised a bit more, so I had my crew put patio block under the supports, which was approved by said engineer.
I try not to make a habit of second guessing & calling out the engineers. But I do know a few engineers that do.
Thanks for the heads up, mate.
Big difference between a "Site Engineer" and a "Structural Engineer" in my working life I sat on the main board of the Institute of Structural Engineers and a few other construction related Institute's and Association's, so know a little about the process.
You can prevaricate as long as you like, but that trench should have been blinded and not as shown as bare earth which would contaminate the concrete.
Unless I've missed something, you're arguing with an electrician who is following an engineer's instruction. It's not really their place to tell that engineer how to do their job.
The problem is that most Electricians would not know the difference between a "Site Engineer" and a qualified "Structural Engineer" a Structural Engineer would never have allowed the concrete to be cast on earth and onto paving slabs as spacers.
It WAS questioned, the whole deal, before I got there. (Thought I made it clear) I was told, "this is what we want." My boss did say it should be on top of a "pad", the engineer disagreed, till the day before our first pour. He said it should be raised up off the dirt. You almost HEAR our eyes rolling into the backs of oue collective heads. The blocks were my (cheap, easy) suggestion. Had to send guys in to pry it up on each side at each spacer to do this.
You've made me out to be an: "OK BOSS I JUST DO AS I TOLD". I try to pick my battles, carefully. I came in and read the room correctly. We knew it was at least sufficient (50-100 years?) before the feeders would be in question. Structural engineer, site engineer... whatever; his seal is on those prints.
Cheers
PS. You've helped prove my point: every engineer thinks they're correct.
There should not be any dirt for it to be raised off, and to add to your comment, every Electrician thinks they know more. :rolleyes:
[automerge]1601507255[/automerge]
Oh I dunno, met a few dipstick Engineers in my time, by all means question them politely
Most Qualified Engineers I find to be very sensible, it's the ones who are not qualified and call themselves engineers that tend to be dipsticks, but then I find a lot of supposedly qualified electricians to be very off the wall.
A very derogatory comment about electricians that.
Well I did some conduit last week, it started as 3 pieces and I got a bit carried away... I wanted some practice. I learned a lot about measuring sets, something I sucked badly at, not easy when we don't really have bending formulas in the UK. Shame we only get to do 3 or 4 small steel conduit installs a year. No conduit graveyard at the end either! If I did it again I would plan the routes so the pipes didn't cross over, oh well.
Reply to In your country, do you use pipe to run wire through very much? in the UK Electrical Forum area at ElectriciansForums.net
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
Hello, I have 50 ft of corrugated pipe buried between my house and a pool shed. I placed it where I knew future landscaping would make it very...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
DIYer here. I'd like to install an electric car wall charger myself. It calls for 6/2 romex which I have. Unfortunately my panel is in my...
I'm in Raleigh, North Carolina and have a well for my house's water supply. For some reason, pitless adapters, which allow all piping to be run...
