Discuss Induction Motor in the UK Electrical Forum area at ElectriciansForums.net
There's this motor that has recently developed a problem. The motor draws alot of current when running, close to three times it's rated load. Any clue to fixing it?
Also what is the motor powering? It might be a problem with that.
maybee 1 squirrel is getting more than his fair share of nuts. this would cause bad feeling from the other 2 squirrels, thus creating a phase imbalance. :90: :grin:
Haha, it's obvious when you think about it......
We would need alot more information DUCKISAR...
-How do you know its pulling 3 times as much when running, is there a Ammeter display or are you clamping the motor supply?
-As above - What is the starting nature of the motor? Is it DOL, Star/Delta, Soft Start unit or VSD to name a few methods.
-Is the motor directly driving through a shaft or do we have a pulley, sprocket etc set up?
-Have you tried to run the motor off load?
-What is the duty of the motor (What is it actually doing as a task)?
-Is it tripping a motor protective overload device?
-I take it the power has been confirmed and all phases are present at the motor?
-Have you carried out any testing of the motor?
Just a few to get us started ... :)
Reply to Induction Motor in the UK Electrical Forum area at ElectriciansForums.net
Friend of mines dryer machine has stopped working, 2 days out of warranty. I am trying to help theme out as money is tight for them however, I'm...
BIG place OK lots of electrical bits. but one on a 3 phase Radial is tripping its RCCB so i check the wiring making sure its tight and it has...
I'm working on a robotics project and currently we are designing a battery. This battery is dedicated to the motor driver and two BLDC motors. I...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
Hello, I wired a DPDT switch to my sunroof 12v DC motor. It was working ok and I was able to reverse the polarity of the motor to open and close...
