T
Tencho1234
Hi,
Im just looking for a little advice on what to install, i have a summer house in the bottom of the garden which i want to run power too.
Im going to installing a new distrubution board and installing a new circuit running up the garden to the summer house im going to use armour core cable and use some electrical warning tapes i know some of the regs and am happy installing it just looking to see what fuses i should install at the distrubution board.
Im going to also install a small distrubution board in the summer house to terminate the armour cable and then install and small ring circuirt supplying a couple of twin sockets and one 13amp fused socket for a wall heater, im also going to install and simple lighting circuit with a single switch. i was going to put in a 6amp fuse for the lights and a 32amp fuse for the sockets or could i use a smaller fuse as there is only 2no twin sockets?
On the main distrubution board in the house im going to use an RCD with a 40amp fuse do you think this would be acceptable, im getting building control in to go through the process of signing off the work.
Thanks in Advance.
Tencho1234
Thanks in Advance.
Tencho1234
