Discuss Installing digital thermostat in the DIY Electrical Advice area at ElectriciansForums.net
O
orange
Hey fellas,
I've bought a digital thermostat to replace and old manual honeywell that's in a bit of a bad way.
I've open both up to check the wiring but the new digital doesnt have an earth. I don't want to start messing with them until I'm sure where it should be placed. I've attached some photos to help.
Any advice would be much appreciated.
Hi there,
Thanks for the help,
I've inserted all wires into the same connections on the new thermo but the display will not turn on at all? any ideas on this one?
Thank in advance!
Check the wiring diagram for the new stat as they are not necessarily the same as the old one. The old stat also would not have needed a neutral to function, the new one does. Is the neutral definitely connected at the other end.
If you look at the back of the new one it has the class 2 symbol.
Hi,i may have missed a bit,but what is it switching?
On occasion,it's not a floor standing Glow worm...
The original may be 10A switching,dependant on type of load,and the new one is rated at 3A.
Probably worrying about nothing...unless you have 1960's electric UFH :)
Reply to Installing digital thermostat in the DIY Electrical Advice area at ElectriciansForums.net
Hi everyone just looking for some advice before buying stuff not planning on carrying out this work myself will get someone who knows what their...
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
Evening all, I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help. While adding some new lights...
Need to replace an old Vent-Axia extractor fan as the pull chord no longer works. I bought this -...
