Designmen90
IP65C
First number: 6 - dust tight
Second number: 5 - protection from water jets
Why is here additional letter "C". This letter C means - Against acces to hazardous part with Tool. But, the enclosure is already dust tight "6", the dust is smaller then tool, so why this letter C is needed?
This document explains the additional codes well
Google; ip code additional letters and it's the top result (in case PDF doesn't work)
  • Informative
Reactions: pc1966
The additional letters are optional and often not used unless for a specific area where it is required.
The codes may not always compliment each other.
Where have you seen IP65C? Is it on a particular piece of equipment, a specification or sonething else?
IP protection
Designmen90,
davesparks,
