Discuss Is it me???? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Each slate has been lifted, cut and put back. Funnily enough because there are so many different sizes if one of the bigger slates is damaged it's being used to infill smaller ones. Needless to say we've got an experienced roofer on the job!
Our first install was on similar roof to that. It was for a mate of mine, and as it was for my MCS inspection and I needed a first job, I agreed to do it for the price of the materials only.
What a nightmare! The slates were so brittle that you only had to put slight pressure on them and they cracked, and it took us about a week to do the work.
The day we completed that job I made the decision to always use a professional roofer to do the roofing work on our installs.
Reply to Is it me???? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
So today I was coring a 6 inch hole for a kitchen fan, now I cut my hole in the kitchen plasterboard and used a long sds bit to drill out the way...
Hi all, I'm planning to remove a stud wall seperating my dining room and kitchen. On the dining room side of the stud wall, there is a double...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi, Recently I had solar panels fitted and realised how they have done it and I hope someone will be able to give me advice how bad and dangrous...
4K
