Discuss Is there a gas/heating engineer here? Quick question in the Central Heating Systems area at ElectriciansForums.net
Astro
Is this an "energy certificate" which needs to be filled in by a gas engineer and sent to a council after boiler replacement is completed?
If so, where should i put the sticker which was originally on the boiler?
and cut that USE ( united states of eurine) flag off first.
So last week i had a gas safe engineer doing some remedial work and commissioning a boiler in my house. Unfortunately he told me, that he needs a document (energy certificate?) which came with the boiler to sign everything off & issue a gas safe certificate, but all the documents which came with the boiler were in my second house. He told me "Get an energy certificate which was attached to the manual, put a sticker you'll find on the top of the boiler on it and bring it to my office next week". But the only document which looks like "energy certificate" i found is the document attached above :(
Who bought the boiler?
might be able to download the manual, what boiler is it
Vaillant ecotec 825.
I found "Benchmark commissioning and servicing sheet" in the manual, so i think that my original question is sorted.
He also said that he'll give me a certificate which confirms that the installation is airtight (im assuming that this is "Gas safe certificate"). Are there any other documents i need to get from him?
You need to be asking these questions on the plumbers forum...#
Reply to Is there a gas/heating engineer here? Quick question in the Central Heating Systems area at ElectriciansForums.net
Hello there, I’m in the process of mapping out a relatively standard S-plan system for my parents central heating and hot water system. Not sure...
About 15 years ago, after having had a modern consumer unit fitted, and prompted by our electrician, I asked my then energy supplier (Tonik) if...
5K
Hi all, First post here, hope I'm compliant with the rules! I did do a quick search before asking this, but I couldn't quite come up with the...
Hi all, first post so go easy! This is for people who are looking for more info on the course and exams and is from my experience of doing the...
