Discuss Is there a protective cover for the 'BACK' of a dry lining box? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Hello all..
I have been asked by a customer to fit a recessed socket in the kitchen. The socket will be located on the side of a cupboard (no other viable options). I have given them options of nice looking wooden surface boxes but they are adamant they want it recessed.
I want to cover the back of the dry lining box with something as it will be accessible once the cupboard is opened and I think the box is designed to be hidden in a cavity.
I could easily make a wooden box thats fits over it inside the cupboard and screws into place (still an hours work) but I wondered if there was an actual product for this or if anyone has any better ideas for making it safe?
Cheers..
Here you go:
Chuck the lid away and secure the container in place with trusty Gaffer Tape (the Roadie's best friend)
use a surface box in cupboard. should get away with a 16mm one once taking the thickness of the chipboard into account.
I had thought of that Tel but just assumed it wouldn't be big enough! I'll have a practise when i get home.. cheers!
... Just thought , do you mean 'Just' a surface box (inside cupboard) instead of a dry ling box?
yeah. a surface box. cut the cupboard hole just undersized for the box, then sandwich box/chipboard/socket front
Reply to Is there a protective cover for the 'BACK' of a dry lining box? in the UK Electrical Forum area at ElectriciansForums.net
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
An odd question granted but bear with me. I've got to extend a radial circuit in a community centre to fit a new hand dryer in the toilets, but I...
A friend of the family recently lost her husband to the big C so I need to be careful. Every small thing is sending her into tears so when her...
Hi, This post is about my concerns with medical IT socket outlets and want to alert you all if you are fitting them in a hospital. The current...
Hello everyone, Following on from my previous post where I received advice on taking a spur off a 40a feed (thank you). I performed the work...
