Discuss LED fitting blowing after several days??? in the UK Electrical Forum area at ElectriciansForums.net
Chris
Hi,
i recently fitted 2 Searchlight LED globe pendant fittings in a property, straight forward job just a switch wire, neutral and earth in the fitting. Each controlled by a separate switch
A day after fitting them both the customer told me that one of the fittings had blown and tripped the MCB, the fitting had been on for a while when it blew. 5 days later the same thing happened with the other fitting but it had been working fine for the entire time.
I contacted searchlight who replaced the fittings for me and i put one of the replacements back up 3 days ago.
the customer has just contacted me to say it has blown again.
Any ideas?
thanks
Most likley a faulty batch of light fittings
However it would be worth checking the voltage at the property.
Faults with N on the supply side can cause strange voltages form 0 to 400v across a single phase.
thanks,
the voltage was coming in at 243v so nothing too drastic, will have to check the batch number of the faulty fittings and see if they are the same.
Reply to LED fitting blowing after several days??? in the UK Electrical Forum area at ElectriciansForums.net
I'm not sure what's going on with my kitchen light. I've replaced an old 28W CFL fitting with a new 4 x LED GU10 fitting (a cheap one from...
A friend of the family recently lost her husband to the big C so I need to be careful. Every small thing is sending her into tears so when her...
Had a new unvented Boiler fitted as the old one had reached the end of it's life. Electrician mentioned that it might be worth replacing my fuse...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Hi All. Its been ages since I have been on here- Fortunately log in details stored on PC. I have just had a new boiler and 210 ltr unvented tank...
