Discuss LED lights for stairs, skirting in domestic dwelling in the UK Electrical Forum area at ElectriciansForums.net
Yeh the clue is in the title domestic victorian property. The usual three up three down terraced victorian property.
Very nice indeed @Midwest but a bit too expensive for the client they are more B&Qish. Love to do a project like that though. With that quality. I love lighting personally.
Hers some B&Qish , trade rated apparently.
http://www.NoLinkingToThis/p/lap-re...tracking url&gclid=CI_0spDax9ICFaIL0wod2YYCEA
Stair lighting in wood handrail or if stud walls led tape profile mounted in wall looks good, better not to see the led tape direct on as looks tacky. See companies like Monoled or gap lighting for help. If a job is worth doing, do it well. B&Q is not the place for quality light fittings ok for a home owner but trade! Better to be known for quality work and use quality marerials. Do it once and right first time otherwise replace it every couple of years which is not good for business reputation.
The problem with that is some customer seem to spend their money irrationally.
Reply to LED lights for stairs, skirting in domestic dwelling in the UK Electrical Forum area at ElectriciansForums.net
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
I have a street light circuit on land I rent out. I need to replace 2 of the bulbs. 1 of them is an old Philips 55W SOX Plus, the other is a...
I'm converting my garage and have about 15m of skirting being installed which has a groove in it I wish to install a (dotless) RGB led light strip...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
