Discuss LED strip light support clip in the DIY Electrical Advice area at ElectriciansForums.net
Peta
My aluminium LED strip light has fallen down. The plastic support that it clipped into has cracked apart.
Does anyone know what these support clips are called so that I can buy a new one?
If you know of a better type of clip to use please let me know, these ones are really flimsy.
The aluminium strip light is 21mm wide and 5mm deep.
Thank you.
Honestly I don't think you'll be able to buy the clips on their own you'll have to be creative with other clips or materials they usually only come in the packaging with the light
Thanks Matthew
The clips were awful, they’ve both spontaneously broken and the light has only been up there about two years.
Thanks for your help at least I’ll know to stop looking. The clip is inside a chimney so not visible, I’ll try to cobble something together with string or something like that.
Thanks.
try the clips that fix oval tube. https://www.NoLinkingToThis/p/tower-oval-conduit-clips-20mm-pack-of-5/51047
Have a look at the fitting for the manufacturer and model number.
Reply to LED strip light support clip in the DIY Electrical Advice area at ElectriciansForums.net
Had to remove a led strip from a bathroom today because it’s getting tiled, now the led strip that was there was low voltage but didn’t have...
Hi there, Please can I have some help with the following: I want to have some perimeter lighting in the ceiling which will be using the...
I am trying to put some led light strips under the fenders of my fat tire E-bike. I’ve been looking at led light strips on Amazon, AliExpress and...
I'm converting my garage and have about 15m of skirting being installed which has a groove in it I wish to install a (dotless) RGB led light strip...
Hi all. First post and wondering if someone can help. I have a single colour LED COB that I’m having issues with. The strip is to be controlled...
