I've been asked to look into lighting in a customer's skirting. Now a quick look through JCC's catalogue comes up with their range of Eltino lighting which at 20mm deep seems perfect.
The only issue i can see is the transformers are built into a 3 pin plug.
The idea is to have these on a PIR so as you walk into the room there is some light.
Fused down socket under the floor boards? anybody done somthing similar?
Or is there any other shallow led's that don't use a transformer out there?
