Discuss Light to turn on when opening automatic garage door in the DIY Electrical Advice area at ElectriciansForums.net
Linbury
Hi Everyone,
I have the (luxury) of an automatic garage door. The motor to this door is powered by a standard 3-pin domestic plug. There is a standard on/off light switch in the garage to turn on these 6 LED battens (https://amzn.to/38BJ5ws) in there. The lighting circuit is on a separate circuit to the garage door motor.
I would like to add another switch to this lighting circuit so the lights turn on automatically as soon as the garage door is opened. (I want to keep the existing on/off switch to act as an over-ride switch, so I can keep the lights on if I wish when the garage door is closed.) A PIR wouldn't be suitable as 99% of the time, it would be used when I open the door from the fob whilst I'm still in my car, so wouldn't be able to pick up IR "heat" from that far.
So, I was thinking of using a microwave switch, that would detect any type of movement or some type of other switch that would detect when the garage door is opened. The garage is detached from the house.
Can anyone help with what type of switch would be best?
How would I wire it up to the existing lighting circuit?
Kind Regards
The forum has a policy of not giving step by step advice members with little or no electrical knowledge. Whilst we can advise in some circumstances your project is beyond our policy of giving a bit of advice. Your best option is to seek the services of an electrician to ensure this is done in a safe manner.
But it's OK to suggest possible solutions in principle, surely, if wiring instructions and component details are not given?
Some garage door openers have an output to feed a light that switches on when triggered by the fob - check the specifics of your model. Because the door motor and lights are on different circuits, a relay would be needed to interface between them so that a dangerous interconnection of the two circuits does not occur.
If your door opener does not have a light output, a current-sensing relay could be installed in its power cable, set to ignore the tiny load of the radio receiver but trigger when the motor starts up. The same precautions applies about maintaining separation between the lighting and motor wiring.
Or, as you originally visualised, a proximity switch could detect the position of the door.
Reply to Light to turn on when opening automatic garage door in the DIY Electrical Advice area at ElectriciansForums.net
I plugged a drill press directly into a GFCI outlet in the garage. Something blew up by the drill press switch. Since then the GFCI outlet LED...
Hi I'm looking for some advice for adding a time delay on my parent's shower room fan. My parents had a section of their garage converted into a...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
My 4 year old son won't go to bed without the light being left on and insists his door is closed when I leave. When the door is opened later to...
Hi everyone, I've got a garage with a circuit that looks like this: I believe it's a radial circuit coming out of the MCB with a current...
