Discuss Lighting circuit calculation help in the Industrial Electricians' Talk area at ElectriciansForums.net
B
bathcity
Hi everybody,
I've been asked at college- when installing additional lights to a house, whether it is necessary to install a seperate circuit when the existing lighting circuit already contains 10 lighting outlets. I know as a rule of thumb it's 10 lighting outlets per circuit, but what calculations do I use to determine this?
Thanks in advance.
The OSG diversity calc recommends a mimimum of 100W per lampholder or the connected load. 100 X 10 = 1,000 W = 4.3A. With the increased use of CFLs and LEDs the recomendation may one day change but there are stil lots of 5 X 40W light fittings being sold.
I think it is possible to have 11 or 13 lighting outlets, depending on the rating of the protective device used, i.e 5A fuse =11 outlets, 6A MCB = 13 outlets but, as you already mentioned, best practice would be 10. I may be wrong, but that's how I understand it.
Reply to Lighting circuit calculation help in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi everyone, after temporary removing a Sonoff that I've installed years ago to do some painting, I'm unable to get everything back to work. I've...
Summary (TL;DR) Several lightbulbs in my home supplied by one circuit breaker dim over time and go out in about a year. Right now, the ceiling...
Hi all, Great forum with lots of advice read and greatly received over the years! I have a question here that I am hopeful somebody here can...
