Discuss lighting circuit pre 1966 warning labels in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
TCES
Can anyone help me on this? I have just replaced a consumer unit on a property that has no cpc on the lighting circuit (pre 1966). All class 2 equipment is fitted and NICEIC technical have been consulted along the way for my peace of mind. I need to apply the black on yellow warning sticker stating that no cpc is fitted to the circuit in question (see http://niceic.com/Uploads/File1946.pdf page 7). I don't seem to able to find them. Can anybody tell me who does the sticker and where to order from. I'd be very grateful. Thanks, Graham
If you have your label printer loaded with the yellow plastic reel, just print it. It doesn't have to look exactly the same, so long as the content is clear and worded as is, in a similar sized and legible font.
I hope not a prob, I do this when out of labels ...
Good idea! My printer doesn't do multiple lines though, so this could be a very long label..but at least it's an option. I've temporarily left a written label on the CU pending getting the right item. I just thought it should be easy to buy it off the shelf. Thanks for the suggestion.
Reply to lighting circuit pre 1966 warning labels in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I've tried to research and form a plan without asking on here, but I'm just going around in circles. Just completed an EICR. The wiring ranges...
S
Brief description of prospective work: Domestic garage, replacing 2 x GLS bulb lights, each with their own separate switch, with one fluorescent...
4K
Skint Eastwood
S
ElectriciansOnCall are a Kent's premier and most accredited electrical contractor covering all CT and ME postcode areas. From changing a faulty...
V
Hey guys, i have started to do some inspecting and testing, i am finding it very interesting although the certification part is a little confusing...
4K
Hi Folks, Went to replace a couple of light fittings today. No CPC on lighting circuit at all, except the supp bonded bathroom fitting. OK that...
