Discuss LUTRON Grafik Eye 3106 instal sanity check in the Australia area at ElectriciansForums.net
I
ianbrookes
hi there, anyone able to sanity check a Lutron install I am about to undertake?
see the diagram.
I have a 3106 control panel, six zones and three Lutron slave units (accessory panels) with a number of lighting circuits.
power into the lutron control.
zone power cabling from control panel to junction box.
12v and data from control panel to slave units.
lighting circuits (lighting radials) back to juntion box to join up with zone cabling.
am I missing anything - or is there a better way to do this?
thanks.
the lutron systems i've done we didnt use a junction box but just wired everything to the unit. plenty of room in the back box.
I have the back box and it does have lots of room. The customer wanted a junction box incase he wanted to change how the lighting circuits work (I think).
Reply to LUTRON Grafik Eye 3106 instal sanity check in the Australia area at ElectriciansForums.net
Hello, I have installed 6 recessed lights in my living room as well as wall boxes. I’m now at a point where to need to run the wiring. I plan to...
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
Hi all, I have a log cabin in my garden. An electrician ran an armoured cable from my consumer unit to the log cabin and this terminates on the...
Hi folks, I have been researching the NEC and forums on the Internet in preparation for adding an RV subpanel electrical hookup. I could use a...
