Discuss Lutron testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
S
sparks1653
Hi,
i have installed a Lutron Graphic eye 3000 series lighting system on a new build project. it has come to testing and certifying the property. i was wandering how the best way to produce the certificates is? does the Lutron controller need a certificate of its own, or do i just test all the circuits supplied from it to make sure they are safe and correct but only write the certificate for the main board and include readings for the lutron control units?
cheers,
Jess
The Graphic Eye is essentially a fancy (but very nice) light switch, treat it as a dimmer - ie disconnect it completely from the circuit, and connect the circuits through with connector strip.
admittedly there will be a few more legs to the circuit than on a normally dimmed circuit, but I usually record the worst case/highest value.
Reply to Lutron testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A long time lurker this is my first post. By way of introduction I have an interest in automation and smart homes - principally Loxone and Shelly...
NAPIT Certification Scheme Third Party Certification
Is there anybody out there in NAPITs Third Party Certification Scheme who would be willing to certify a new consumer unit I am wanting to install...
Hi there. I’m hoping for some advice. I currently run a small limited company that provides IT services, both commercial and domestic so I...
Hi all, I'm currently training thru a company called tradestech, not very impressed so far, I was told that within 6 months I'd be able to...
Background Two weeks ago, lightning struck a tree in our yard. Many circuits tripped and several electronic devices failed. There was a strong...
